Ecotect Analysis Forum (Read Only)
Light Reflectance
3 REPLIES 3
r.cazenave
820 Views, 3 Replies
Light Reflectance
I use ecotect/radiance to run Daylight factors studies.
I have a problem to set light reflectance of internal materials (floor / walls / ceiling):
- what value should I enter ? LRV value or L* Value ?
- Where should I enter that value: in the materials properties solar absorption (see picture 1) or in the color editor (see picture 2)
It changes really much the results.
3 REPLIES 3
arqyt
in reply to: r.cazenave
if you click on "Highlicht: Lighting"
In that action you can see the parameters that affect in that calculations.
Good weekend
Jose M Carralero.
ArqyT
r.cazenave
in reply to: arqyt
OK. THank you.
But I have the LRV value of a material.
Where do I enter it ?
In solar absorption (1- LRV ?) or in colour (reflect.) ???
arqyt
I don´t know what is LVR, is not similar abbreviation word in my country. But if you want to do a interior lighting analisys the main parameters are:
- Color reflected interior
- Specularity interior
if you have doubt try to explore the parameters value of the material library. It is ever a good began.
I hope help you
Jose M Carralero.
ArqyT
