Ecotect Analysis Forum (Read Only)
Importing lights into ecotect via gbxml
1 REPLY 1
1167 Views, 1 Reply
When I import a gbxml file into Ecotect, the objects of type 'light' are not being imported.
I try to export a model from revit into ecotect to be able to do lighting analyses. The lights are being exported from revit into the gbxml file, but are lost during import.
When exporting a model form ecotect to gbxml, the lights - which I created in ecotect itself - are also not being exported.
May I conclude that gbxml interface of ecotect does not support lights?
1 REPLY 1
hello! I met the same problem as yours. Have you solved the problem? I really have no idea about it.
