have somebody tried to batch render a precached Bifröst sequence with mentalray without meshing?
I mean the option to render the iso-surface of a Bifröst-Particle System without meshing.
Rendering still one frame is possible.
Rendering via Batch will render only Frame 1 and then stops.
Would be nice to know if i made a mistake. Batchrendering the Isosurface without meshing would be great to get an idea for the final mesh....
ok, for my setup it will only work to batchrender a iso-surface of bifrost if you start your render with the 1st frame of the cached (!) simulation.
Batchrendering between a cached simulation will not work.
This is a known issue with Maya 2015 and is fixed in 2015 SP1.
Unfortunately there is a (sigh) bug in SP1 that prevents the mentalray Bifrost libraries from installing correctly, so you can't render Bifrost liquids at all. My advice is to completely uninstall Maya 2015 including mentalray and install Maya 2015 SP1 fresh.
What is Bifrost?
Is a part of Maya, or a plugin,
I've just heard of it, as a plugin used to generate or render liquid simulation.
How to get it? and where to download it?
Please help me out))
Hi Adrian
I have found that if I render Bifrost Aero caches with batch render or on a farm the frame takes hours (9+), but if you render with the render view its less the 10 mins?
Something is happening with the stratch cache loading all the frames i think, as this is the default setting when loading a scene on a different computer.... maybe
so i ended up usin this python script to render from the render view
@hoganburrows, sounds like you're trying to render a non-cached simulation? Maya may be trying to run up to each and every frame. Is it the SIMULATION or the RENDER that's taking so long?
When you render from the command line, make sure to specify the flag '-mr:v 5', which will spit out detailed mentalray stats to the terminal.
BTW, I did a tutorial on converting BIF to PRT on my blog here:
http://area.autodesk.com/blogs/valhalla/converting-bif-files-to-prt
@Kerim95, uh, that's an...interesting question.
I'd start here:
http://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Maya/file...
