I have a Ncloth box on nucleus 1 , and particles emitter assigned to Nucleus 2...
I need to make that Ncloth to be a passive collider to those particles, but by keeping each assigned to Nucleus 1 and nucleus 2
Is there a way to do that ?!
First take the ncloth box ncache, than go to nmesh menu and remove ncloth.. you will lose your ncloth.. do not worry.. go on .. and go to ncache menu and select your box , than attach exixting cache file to it..
it should work..
now for collide with particles with nucelus 2
select your box and go to nmesh menu and click the "create passive collider"s option box.. select your second nucleus (which connected to particle) than click apply:))
enjoy it...
