I recently get Maya 2015 and was very interested in Bifrost to simulate fluids. I tried with provided samples but I always have the same problem : when I run the animation to compute the simulation, the timeline becomes red, all frames failed. Even with a minimalist scene (polyCube fill of water), same error.
Someone have an idea ?
Hey guys! I think I had this problem too, but fixed it somehow weeks ago. Do ya'll have your scratch disks enabled and background processing enabled? Go to the bifrost options and make sure both are checked and have it so you have enough RAM allowed for the background processing to use to allow this. If it doesn't work, you should upload a picture of your scene so I can at least visualize how it is set up.
install sp5 by turning of antivirus
it worked for me
I have the same issue and have tried everything. I have SP 5 and still Red timeline. Every frame fails. man dont know what else to try. I am ready to try a new system install because I need this to finish this sememster and I would like to keep using it it is amazing but frustrating not being able to run sims on this new machine I built SPECIFICALLY to handle simulations because the Macbook pro could not handle it anymore. But now I cant even get it to work/:
WHat version of Windows are you running. I have 8.1 Enterprise
Not same problem. We cannot even get one simple piece of geometry to become liquid in the scene. The fluid container stays small at origin. On school PC it make container around all the scene practically. So yours is working and sounds like a Cache issue but ours is not completing even a single frame of the Sim.
Okay i fixed my issue with bifrost not working at all... turns out avast is a bitch and deleted some important bifrost files when i originally installed maya.. so i unistalled maya reinstalled it (which in itself is a bitch) and i had the antivirus turned off while doing this.. just booted up maya and tested it out.. bam..everything now works.. AVAST WILL BLOCK BIFROST... hope this helps everyone..
ALL you have to do is save your scene right before you cache it and it will work just fine.
Hope this helped
Is everyone else up and running now?
Or are you guys still experiencing problems?
Reading through the posts...
yes, if you are using Avast antivirus then Avast will quarantine specific .dll's associated with Bifrost. So you will have to disable Avast to work around this.
Make sure your object is big enough. If you create a bifrost liquid sim on a sphere or other object that is too small then it will appear to error.
red timeline usually indicates a problem with a frame that cannot be loaded. (cache or sim, .bif file cant be found or something is wrong with the sim)
