Who can help me with my dynamic block.
The block is a piping with various links that back together and they should stay behind each other, they are not go over each other otherwise the spacing is not good after data extraction.
The distance between not less than 100 mm and the total length should not exceed 5000mm are.
Furthermore, they are relatively movable from each other.
I've been working with linear parameters and constraints, but that's not good as far as I know I can not apply visibility later with links that point to the other side.
Does anyone have an idea for me to get started.
As a guess:
If the Valves will only move to the right the Stretch Selection box should encompass and the Stretch Action (Stretch would include T6, T2, and T9; Stretch1 would include T2 and T9; Stretch2 would include T9) should include each to the right too.
This will not affect how Stretch1 or Stretch2, or Stretch3 act on the one specific part of the Valve as you have it.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
