Dynamic Blocks Forum
dynamic Block doesn't move attributes
3 REPLIES 3
Klingi162
634 Views, 3 Replies
Hey guys,
I'm working on a dynamic door block, which allows me to add some hight and witdh values to the door. everything works fine when I put in the attributes right away when I insert the block. Only if I want to mirror and strectch the block before I enter the values they want move to the correct position. After I run "attsync" it moves to it's correct place...quite annoying if I always have to use this way.
Is there a better solution to that issue?
Thanks for your advice folks,
cheers Klingi
3 REPLIES 3
Charles_Shade
in reply to: Klingi162
That is a limitation of DynBlk's. If you want the Attribs to stay but not print anything try using %% for the Value.
It will remain blank and the Atrribs should move as expected.
Klingi162
in reply to: Charles_Shade
hey charles,
I already thought that it's a limitation within the program...
thanks for your advice, but unfortunatly the "%%" didn't change its behaviour. 😞
maybe I have to live with it, but it's not really useful
Charles_Shade
Yea, should have tested before I put that out there. Would be nice because I have a few that need that as well.
”Boost
”Tips
”Services
