First time poster here so be nice :).
I am attempting to make a schematic block for a stage floor pocket which has plugs for stage mics, monitors, etc. I have visibilities set up for 1-12 microphones and several attributes adjusting other things about the block. However, when adding multiple floor pockets to a schematic, I want to be able to give a starting number (for the first mic) and then have it auto number the mics based upon that input.
I set up an attribute to be the input and have my row of mic's setup to be I, I+1, I+2, etc all the way down the line, and it works upon first inserting. But if I input a new starting number it won't recalculate the other mics.
So two questions:
1. Is there a way to call the express automatic text numbering function from within the block and use that instead of what I'm doing?
2. Is there a way to recalculate the mic numbers after changing the starting number?
