Dynamic Blocks
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
array multiple objects sequentall y
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Greetings,
It seems like this should be easy but it's not. I have a block with multiple components. I want them to array sequentally as I drag the grip. First one component, then the next, then the next. What I get is all 3 at once when I drag the grip far enough. I tried 3 seperate linear parameters with their grips stacked but that didnt work either. What I have attached is a very simplified version of what I want, but I think once I get the concept it will be easy to elaborate on.
Thanks in advance,
Dave
Re: array multiple objects sequentall y
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
is it what you want?
Juris
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That is perfect. Thank you very much!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You`re welcome
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Juris,
I would like to know how did you do it?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Distance1 is the Parameter that Stretch, Stretch1, and Stretch2 are linked to.
Stretch controls the Distance4 Parameter that is chained to Distance1. Meaning that when Distance1 is activated the Action that is linked to Distance4 will also activate. Tha Arrays are linked to the relevant Parameters and logical distances were assigned. The circle needs to move 800 units to get to its first position, etc...
The rest of the Parameters and Actions are similarly setup.
(I just hope Juris had to trial and error this and did not just do it in one shot. I might have to not like that guy anymore if he did.
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
As a Post Script here is the block that I was actually working on. It took quite a bit of trial and error, and i still don't understand why the distance parameters have to be set to the lengths that they are.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
may be You can save to 2012 version?
In this moment I can`t have 2013 version
Regards
Juris
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sure, no problem.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks a lot Charles ![]()
