• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Dynamic Blocks
    Active Contributor
    array multiple objects sequentally
    321 Views, 9 Replies
    09-28-2012 07:40 AM
    Greetings,
    It seems like this should be easy but it's not. I have a block with multiple components. I want them to array sequentally as I drag the grip. First one component, then the next, then the next. What I get is all 3 at once when I drag the grip far enough. I tried 3 seperate linear parameters with their grips stacked but that didnt work either. What I have attached is a very simplified version of what I want, but I think once I get the concept it will be easy to elaborate on.
    Thanks in advance,
    Dave
    Please use plain text.
    ojuris
    Re: array multiple objects sequentally
    09-28-2012 08:31 AM in reply to: ddepriest
    is it what you want?
    Juris
    Active Contributor
    09-28-2012 08:36 AM in reply to: ojuris
    That is perfect. Thank you very much!
    ojuris
    09-28-2012 08:37 AM in reply to: ddepriest
    You`re welcome
    Distinguished Contributor
    jz4all
    11-13-2012 01:54 AM in reply to: ojuris
    Juris,
    I would like to know how did you do it?
    Thanks.
    Charles_Shade
    11-13-2012 05:01 AM in reply to: jz4all
    Distance1 is the Parameter that Stretch, Stretch1, and Stretch2 are linked to.
    Stretch controls the Distance4 Parameter that is chained to Distance1. Meaning that when Distance1 is activated the Action that is linked to Distance4 will also activate. Tha Arrays are linked to the relevant Parameters and logical distances were assigned. The circle needs to move 800 units to get to its first position, etc...
    The rest of the Parameters and Actions are similarly setup.
    (I just hope Juris had to trial and error this and did not just do it in one shot. I might have to not like that guy anymore if he did. :smileyvery-happy:)
    Regards, Charles Shade            Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
      Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Active Contributor
    11-13-2012 06:32 AM in reply to: ddepriest
    As a Post Script here is the block that I was actually working on. It took quite a bit of trial and error, and i still don't understand why the distance parameters have to be set to the lengths that they are.
    ojuris
    11-13-2012 06:48 AM in reply to: ddepriest
    may be You can save to 2012 version?
    In this moment I can`t have 2013 version
    Regards
    Juris
    Active Contributor
    11-13-2012 06:50 AM in reply to: ojuris
    Sure, no problem.
    jz4all
    11-14-2012 02:57 AM in reply to: Charles_Shade
    Thanks a lot Charles :catvery-happy:
