Have you gotten any farther with this issue? Our office seems to be having the same difficulties...
A similar request came up here in the last couple of weeks though I do not believe a solution was found there either.
In both cases the OP's are assuming that a single Dyn Blk at different scales will somehow be several different Dyn Blk.
If you make a change in one scale the block is going to change across all scales because it is the same block.
While making these Annotative offers greater flexibility across multiple Viewports there does seem to be some significant drawbacks when it comes to text involved with those Blocks
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Hello, and thanks for the post - is there a solution to this?
Basically it means that I need to stretch the block back and forth each time when switching scales is that right?
Thank you!
