Solved by rapidcad. Go to Solution.
I love the sound of this lisp, it's exactly what I've been looking for but I can't get it to work.
I can add a visibility parameter using (visibility_add) which it does but with errors;
{color:#3366ff}Command: _appload visibility-add-eng.lsp successfully loaded.
Command:
Command:
Command: (visibility_add)
Select point for placing Visibility Set: _.BParameter
Enter parameter type
[Alignment/Base/pOint/Linear/Polar/Xy/Rotation/Flip/Visibility/looKup]: _V
Specify parameter location or [Name/Label/Description/Palette]: _L
Enter visibility property label : Visibility-1
Enter number of grips [0/1] <1>:
Command: _.BSAVE
Command: ; error: quit / exit abort
{color:#000000}I then rename the parameter as in step 4. And try to set the new parameter active using (visibility-up) but I get the following error;
{color}
Command: (visibility-up)
Select required Visibility Set: ; error: bad argument type: numberp: nil
{color}
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<GemT> wrote in message
href="news:6242557@discussion.autodesk.com">news:6242557@discussion.autodesk.com...
loaded.
Command:
Command:
Select point
_V
_L
Specify parameter
<1>:
Command: _.BSAVE
abort
error;
{color}
{color}
Am I missing
something?
I am using AutoCAD 2010.
Any help would be greatly
appreciated.
Thanks.
Gemma
<GemT> wrote in messageWell
href="news:6244223@discussion.autodesk.com">news:6244223@discussion.autodesk.com...
I got around that by deleting all the vp's and starting again...lets try
again.
Gemma
Try version 1.3: http://www.private.peterlink.ru/poleshchuk/cad/2009/tainypod12e.htm
