hello
I have created a small dynamic block that manipulated some lines (attached). The properties table allows s1, b1, b2 and c to be modified. The white lines control the cyan and red.
The red-lines have an array within (green lines) which I want to lock to the blue line parametrically. The array may be dragged physically but thats not the point; its need to be automatic (Revit style).
Any clues on how to please.
Make a linear parameter with an array action attached, just like you normally would.
Select the parameter, properties, Grips: 0, and set Chain action parameter to 1.
Then include your array-parameter in the stretch action for your blue line.
Now everytime you stretch your blue line the red/green will follow with array.
Adam
Thank you for the advice. I tried everything to get it to work to no avail. However, I have finished the model and its only the dynamic array that is letting the side down. Would you have a look at the model for me please. I have tried dimension contraints in both the model and in the drawing-object.
The forum will not let me attach the drawing (5kb minimum and the model is 171kb) so I have put the model on my server, if thats ok.
Link http://www.hemis.co.uk/projects/cad/cad.html.
Regards
Daniel
