Howdy all,
First post here.
I'm having trouble getting a set of parameters to work together in this block i have created.
File attached for reference
Block 1 (EXTENT_OF_WORKS) and Block 2 (EXTENT_STRETCHED) are attached to file.
As is on both blocks i need a central insertion point/base point.
Block 1 has two rotate commands. The inner rotate command is to align the block so that it is perpendicular on a straight line of a route. The outer is to align perpendicularly in the case where the centre point of the block falls on an arc segment of a route.
Block 1 has also got a flip command.. to flip.
As is block 1 works well. but i also need a stretch command that can extend both ends of the block, away from the centre, at the same time. See block 2.
I have tried to complete this block in multiple ways to no avail.
Any input or advice appreciated
This it?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Mr Shade,
thank you very much
it works perfect now.
no external commands. woot.
i have tried to emulate your stretch but cant
i previously used a single parameter and chained the actions. result see image attached.
i see the 180 angle offset on the stretch action, but i dont understand that.
how does your block work? how does it stretch equally?
or if you can identify what may have been going wrong when i chained my actions. image attached
hi!
Charles add both stretch actions from same linear parameter end - that`s why he needs 180 angle offset
There is another version - change base location for Linear parameter from Startpoint to Midpoint and add stretch action on each end without 180 angle offest (attach file)
Regards
Funny - It was only recently that I noticed that you could do what I did and not as you have described Juris.
Always did it your way AND set the Parameter to Mid-Point. Redundant.
Good to hear from you Juris.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
hey guys,
i have looked at both your blocks and they both work great, however, i am unable to emulate what you have done.
i have tried offseting the stretch action by 180*, as is done by mr shade. but only one side is stretching stll.
my first attempt was similar to ojuris, but i had also chained my actions. i tried the base location=midpoint again,without chaining, and still it does not work well for me.
ojuris, see eow.jpg image attached to 3rd post. this is what i get with your method
mr shade, emulating your method gives me a single side stretching and the block obscures off its base point after multiple uses of the rotate commands.
is this a problem with MY autocad, autocad 2010, or am i adding in/leaving out certain things in my action selection sets.
i cant seem to get this one guys. it is defeating me.
attached is another TextOnLine block. i have used ojuris' method. failed.
cheers guys, its a great help, much much appreciated.
my boss should also be thankful as i have been involved in this one block for a while now. well it will apply to many more blocks later tho.
hi!
I think You doing things right except selecting elements for stretch actions
for left side I select only line, for right - line, mtext and only rotation parameter
regards
Juris
