Dynamic Blocks Forum
Stretching same parameter in all blocks in drawing from one field?
1 REPLY 1
Dewlevlak
264 Views, 1 Reply
How do I manipulate a height parameter all of the dynamic blocks in the drawing from one single field? Say a field located in the drawing properties or on the drawing itself.
For example:  Multiple blocks of different walls of same height with other blocks of things on located on those walls, dependant on the wall height, all linked to and changed by a single field. Possibly a Wall Height field located in the custom tab of the drawing properties.
I can pickout each of the blocks and change them at the same time in properites menu because they all share the same parameter name.  I would just like to have that height parameter of every block in the drawing, that has that specific parameter controled by a single field.  Which I could enter a new height at anytime that would change every block in the drawing to that height.
1 REPLY 1
Dewlevlak
in reply to: Dewlevlak
”Boost
”Tips
”Services
