Take your stretch action out of the rotate action selection set. Including
parameters in selection sets doesn't usually cause problems, but actions do.
wrote in message news:5845785@discussion.autodesk.com...
Hello All,
I'm trying to apply a stretch and rotate dynamic to, for example, a block of
a rectangle that is 2 feet wide and 10 feet tall. The insertion point is at
the top, center. I've tried applying the stretch first, starting at the
insertion point and stretching downward. I then saved the edit and tested
the stretch. It works fine. I manually rotated the block 45 deg and can
still stretch along the 45 deg axis. I then go back into the block editor
and apply the rotate parameter starting at the insertion point. I then
select ALL the objects, including the stretch parameter. Then exit the
editor and try the functions. Now starts the problem. The rectangle will
stretch in the top to bottom axis direction, no problem. Now rotate the
block via the dynamic, say 90 degrees, then try to stretch it. It does not
stretch along the 90 deg axis, but appears to move the stretch end
perpendicular to it. In other words, moving the stretch arrow east and
west, moves the end point north and south, creating a parallelogram.
Any help would be greatly appreciated.
Regards
