I wish to have a single dimension alter the dimensions in a set of nested blocks, similar to shared parameters in Revit. For example, I have a circle that has a fixed diameter that I wish to control in all blocks. I have set the diameter to barDia so now I wish to manipulate the dimension from outside the block.
Am I able to share the parapeter across all the blocks, please?
Regards
Solved by AcadAdamLT. Go to Solution.
No, you can't share it between your blocks.
But however, if all blocks are similar or of a similar type/name or other properties you can use Qselect to select all blocks in a drawing containing that parameter and edit the value of all those blocks in properties window.
(Use a stretch action to alter the dimension)
