Hi guys!!
My problem is that yesterday was evertthing ok about it, but now, when I use, for instance, "pe" it doesn´t already appears the semitransparent toolbar next to the crosshair with the options of "pe" and I have to tipe in the command line.... another example, one you have when used "distance", to see what distance is, I have to go to the command line!!!
How I can put this kind of toolbars again in my autocad 204 for MAC
thanks!!!
I think you are referring to dynamic input. I don't use AutoCAD for Mac, but you can try to find dynamic input button in drafting settings. Try to turn it on.
If you can't find it, you should post this question in appropriate forum here: http://forums.autodesk.com/t5/AutoCAD-for-Mac-General/bd-p/520
This is specific for dynamic blocks.
