• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Dynamic Blocks
    Valued Contributor
    Accepted Solution
    Rotation off by 1*
    125 Views, 5 Replies
    11-14-2012 01:58 PM
    Can someone look at the attached block and tell me why when I rotate it, it "shifts" 1*... so instead of rotating to 90*, it's 89*, etc...
    Any ideas?
    Please use plain text.
    Distinguished Contributor
    ojuris
    Re: Rotation off by 1*
    11-14-2012 02:16 PM in reply to: kkline116
    is it now ok?
    Juris
    Valued Contributor
    11-15-2012 04:49 AM in reply to: ojuris
    Yes!
    Can you please tell me what you did? I have other blocks doing the same thing.
    Thanks!!!
    *Expert Elite*
    Charles_Shade
    11-15-2012 05:18 AM in reply to: kkline116
    In Juris' block the Flip Action and Parameter have been removed.
    But zoom in our the Flip Action and Parameter in your version.
    It is not running thru the center of the Rotation Parameter.
    If you change this on yours does the Dyn Blk work as you need?
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Valued Contributor
    11-15-2012 05:22 AM in reply to: Charles_Shade
    Ah... yes. Now it does...
    Now I know you have to zoom in really close sometimes. :smileyvery-happy:
    Thanks!!
    ojuris
    11-15-2012 09:46 AM in reply to: kkline116
    Sorry about delete parameter - that was my fault - I accidentaly delete it   :smileyembarrassed:
    The reason was, that your rotation grip was not on rotation parameter vertical axes and it is not depend from flip parameter. If You draw vertical line through rotation parameter centre - You`ll see what I talking about
    Juris
