I have what I thought was going to be a fairly simple DB that has turned into a challenge I cannot resolve on my own.
It's a "slot" (elongated hole) that allows the user to dynamically change the diameter and the length. These properties work "well enough" (sometimes I get quirky results, but I can deal with it; I may add lookups to minimize exposure to the quirks), but when I attempt to add the ability to rotate the slot, I get a hint (a brief preview) of the block rotating, but when I drop the grip it stays where i drop it, but the geometry reverts back to the default rotation and the message "One or more constrained objects cannot be resolved" shows on the command line. Attempting to enter a rotation in Properties is similarly fruitless.
I'm stumped. Any help would be greatly appreciated.
Solved by dmfrazier. Go to Solution.
Maybe (untested) a Polar Stretch Pair, or two polar stretches in opposite directions, one chained to the other, one with a -1 Distance (?).
Have at it! (I've got to get back to work.)
Without the 'midpoint' option, you're back to half-length input or having the stretch/rotation base point be at the center of the left arch.
