Using the AuoLisp code (vlax-put obj 'Name (vlax-get obj 'Effectivename)) a dynamic block 'obj' can be renamed to the 'effective' block name. However, the visibility state is then reset to the default value. Is there a way in AutoLisp to rename a dynamic block and maintain the current visibility state?
I realize this is an old post, but try this lisp routine. I have been using it for some time.
See attached file, Brename.lsp.
Hope this helps.
