Dynamic Blocks Forum
Redefining D.B. Fields becomes pound signs (####)?
3 REPLIES 3
jarredmonday
990 Views, 3 Replies
I've came across two threads with this similar question without any answers. Maybe someone knows by now...
This seems to happen to fields that are linked to objects. After redefining a dynamic block, from the tool palette, the field in it changes to #### signs. The field is referencing a pline for the length. Also, when I use the UPDATEFIELD command it's updating two fields. Shouldn't there only be one field?
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
3 REPLIES 3
jarredmonday
in reply to: jarredmonday
I forgot to mention the field is inside an Attribute.
I'm using attribute so I can mirror the blocks and have the text with the correct orientation.
Libbya
I believe that when you redefine a block, the polyline the field is referencing is redefined as a new polyline and so the field link is broken.  There are two simple solutions that I have found.  The better solution, IMO, is to have the field linked to a 'block placeholder' and select an appropriate linear parameter.  A not-so-good solution is to place the block in a file, link the field to the polyline object that you want measured and save the block.  Then insert the file and explode it once.
jarredmonday
in reply to: Libbya
Selecting a blockplaceholder was the perfect answer. I used this with other blocks that I was really struggling with. Thank you very much.
”Boost
”Tips
”Services
