Dynamic Blocks
inteso
Message 1 of 9 (601 Views)
Polar array inside a dynamic block
601 Views, 8 Replies
12-19-2013 06:19 AM
I've made this block
when i rotate the vertical line I need to add lines every 15° as you see in the image, i've seen that polar array is not possible in the dynamic blocks.
Can you help me to find a solution?
Thank you for the support
Bez
Charles_Shade
Message 2 of 9 (593 Views)
Re: Polar array inside a dynamic block
12-19-2013 09:06 AM in reply to: inteso
EDIT (ten minutes later): And now I realize I do not beleive that I answered your question at all (below) but will keep that info anyway since it may be useful.
Not sure right off how to get that line to come in at increments but I suspect it is doable.
This has been done in the past using a Dimension line for the Arc without endpoints (Arrows) and no text.
See the attached Door Block.
I think that DIMASSOC needs to be set to 2 to get this to work. Once done you can change that Variable back to what you want.
Or it could be 1. (I've had some issues with DIMASSOC recently that have caused me great grief).
Short of it is if you create the DIMANGULAR and it does not stay with the endpoints that you choose try changing the DIMASSOC.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Charles_Shade
Message 3 of 9 (582 Views)
12-19-2013 11:36 AM in reply to: Charles_Shade
Here's a "fake" as a possible starting point. Doesn't work quite right as the last line will nto drop when you go back to zero.
ojuris
Message 4 of 9 (575 Views)
12-19-2013 12:18 PM in reply to: Charles_Shade
hi! You forgot insert 0 values at lookup tables for visibility and angle, that's why it is not droping last line in zero value Juris
Charles_Shade
Message 5 of 9 (562 Views)
12-19-2013 01:09 PM in reply to: ojuris
Thanks.
This should be better
inteso
Message 6 of 9 (527 Views)
12-23-2013 01:47 AM in reply to: inteso
I'm Trying to attach the block.dwg file but the forum responds with this error "The contents of the attachment doesn't match its file type."
Help me please....
in words... so you would add a visibility parameter associated to the rotation action..... am i wrong?
Charles_Shade
Message 7 of 9 (521 Views)
12-23-2013 05:48 AM in reply to: inteso
Yes that is it; but the Lookup controls both so that you simulate the Rotation by changing the Vis State.
You would need to add a line to the Lookup for each degree that you wanted this to occur.
Try Zipping your file and if that does not work I'll send the attachment issue up the line to see if that can be corrected.
inteso
Message 8 of 9 (482 Views)
12-31-2013 03:37 AM in reply to: Charles_Shade
Same problem (also with Zip file)
Charles_Shade
Message 9 of 9 (477 Views)
12-31-2013 05:18 AM in reply to: inteso
I've asked Discussion Admin to look into your file posting issue. Hopefully that will get corrected soon.
If you would like you can PM the file by clicking on my name or send it to c l shade at c shade design dot com
You are not logged in.
Ask the Community
