Dynamic Blocks Forum
Please, help me create dynamic block with dimension
8 REPLIES 8
Message 1 of 9
minhphuong.humg
1089 Views, 8 Replies
Hello, I need some help.
I have a drawing with dimesions. Now, I want create Dynamic Block Controlling Visibility with dimensions in drawing with name dimension.
LT-don-TD LT-Kdoc-TD LT-Kngang-TD
LT-don-thay LT-Kdoc-thay LT-Kngang-thay
LT-don-moi LT-Kdoc-moi LT-Kngang-moi
H-don-TD H-Kdoc-TD H-Kngang-TD
H-don-thay H-Kdoc-thay H-Kngang-thay
H-don-moi H-Kdoc-moi H-Kngang-moi
Then, I use command DAL; I can select dimension want use.
Please, help me!
Tags (1)
8 REPLIES 8
Message 2 of 9
Hello everybody.
I created Dynamic Block visible with blocks. But I don't know how dimension with Dynamic Block first rowahead (Dimension style). I very try but don't success.
Please, create dimension with Dynamic block visible.
Purpose, I drawing as I sent to you. I can select from list Dynamic block visible instead go to change dimension style on the Styles bar (Dim style control).
Please, help me.
Message 3 of 9
Something like this? The Dim String can be made to anything you want. Just include it in the Stretch Action
There is also a Field with the Value of a line shown as well.
Message 4 of 9
Thanks Charles_Shade,
It that mean of my idea. I tried but have some problem:
- When I change different block (ex. in drawing) is lost dimension (image attach)
- I don't know, I don't understand. What is number 12 under dimension?
Please, help me. Thank you very much.
Image.
Tags (1)
Message 5 of 9
The 12 is nothing but a Field and Is erased in the attached and I have Show(ed) the Dimension and Dynamic Action in all states.
Message 6 of 9
When I change different blocks, lost first arrowhead.
Please, view image:
Message 7 of 9
You may need to Redefine the Block.
Message 8 of 9
Dir,Charles_Shade
I created Dynamic block and Attribute blocks (http://forums.autodesk.com/t5/Dynamic-Blocks/Help-me-lisp-Data-Extraction-to-excel/m-p/4741821#M1606...).
Please, help me write a lisp extraction data of Dynamic block (DimPC) and Attriube blocks (Buble) to excel.
Message 9 of 9
I cannot write that since I do not know LISP.
This Forum may be a better place to start: http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/bd-p/130
”Boost
”Tips
”Services
