Hello, I need some help.
I have a drawing with dimesions. Now, I want create Dynamic Block Controlling Visibility with dimensions in drawing with name dimension.
LT-don-TD | LT-Kdoc-TD | LT-Kngang-TD |
LT-don-thay | LT-Kdoc-thay | LT-Kngang-thay |
LT-don-moi | LT-Kdoc-moi | LT-Kngang-moi |
H-don-TD | H-Kdoc-TD | H-Kngang-TD |
H-don-thay | H-Kdoc-thay | H-Kngang-thay |
H-don-moi | H-Kdoc-moi | H-Kngang-moi |
Then, I use command DAL; I can select dimension want use.
Please, help me!
Something like this? The Dim String can be made to anything you want. Just include it in the Stretch Action
There is also a Field with the Value of a line shown as well.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Thanks Charles_Shade,
It that mean of my idea. I tried but have some problem:
- When I change different block (ex. in drawing) is lost dimension (image attach)
- I don't know, I don't understand. What is number 12 under dimension?
Please, help me. Thank you very much.
Image.
The 12 is nothing but a Field and Is erased in the attached and I have Show(ed) the Dimension and Dynamic Action in all states.
When I change different blocks, lost first arrowhead.
Please, view image:
You may need to Redefine the Block.
Dir,Charles_Shade
I created Dynamic block and Attribute blocks (http://forums.autodesk.com/t5/Dynamic-Blocks/Help-me-lisp-Data-Extraction-to-excel/m-p/4741821#M1606...).
Please, help me write a lisp extraction data of Dynamic block (DimPC) and Attriube blocks (Buble) to excel.
I cannot write that since I do not know LISP.
This Forum may be a better place to start: http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/bd-p/130
