Hello
I need to use the dimension created by an action-parameter as a variable in a user defined function but AutoCAD will not allow me (see attached).
How may I access the action-parameter's dimension please?
Regards
You've probably noticed that this is likely not doable OOTB.
Typically the Value of a Parameter is able to be used with a Field.
Unless you can add a Field to the expression column to get this Value you're stuck.
I did not see that this is an option in the editor.
Or if there is a way to add just a placeholder entitity to that Parameter or geometry that can be used...
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
