The subject may give a pretty good idea of my question. I have a block which I want 2 visibility states. VS1 and VS2 share some objects and not others. I have a linear parameter in each which I want to do a stretch action on. The stretch action in each visibility state acts upon entities both shared and unshared between VS1 and VS2. This doesn't seem to work.. Does anyone know if it's possible and if so what my problem is?
Thanks.
PS-.. ok.. I think I almost have it working now.. I just need to adjust something.. chain action maybe??
Solved by Shneuph. Go to Solution.
Figured it out.. Just copied the shared objects to their separate visibility states.. Actually, the block ended up much different. It's pretty legit. Check it out attached.
Wish I could look but alas, limited Parametrics in LT.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
