Dynamic Blocks
Valued Contributor
Spiritshifterus
Message 1 of 1 (93 Views)
New Issue (hope to learn about constraints)
93 Views, 0 Replies
10-09-2012 01:18 PM
Hello, all.
I've learned much about the Dynamic Block Parameters & Actions. Now, I'd like to continue learning about Dynamic Blocks by trying to understand the Geometric Constraints and Constraint Parameters. I've dabbled with them a little and didn't like what I see.
Here is what I have been working on when I try to use constraints. I have several blocks which are simply a regular hexagon with a 2-line, T-bracket stemmed outside of it to mount the symbol on walls. What I'd like to see happen is have the base of the T-bracket be constrained to the midpoints of each hexagon side and the corner points. Furthermore, when the base of the bracket is at the midpoint of the hexagon side, I'd like the bracket constrained to perpendicular to the respective side. And when the T-bracket base is at a corner point, I'd like the bracket stem to be an outside continuation of the bisecting interior angle line.
I've attached a sample block, performing what I ask by using Move and Rotate actions. I was just hoping that I could lock the stem in to certain specific places, without I or another CADDer moving the bracket far, far away by accident by using Constraints.
I admit two things. First, what I try to do may not be possible with AutoCAD 2010. And second, what I want to do here has no rush on it whatsoever. I simply would like to learn about the Constraints, and where/when/why I might need them.
Thank you all.
Chris Martin
You are not logged in.
Ask the Community
