Can someone help me get the right side of this block file to stretch with the text.
When I add the parameter and action the left side text disappears. It's very strange.
Much appreciated for the help. Thanks!!!
Okay, everyone say it with me now:
All Attributes must have unique Tags. The same Tag cannot be used for two different Attributes nor can you Copy the Attribute so it is present more than once.
Fish are friends not food...
If you need the same info in both sides of the section cut it can be done but you must jump thru a few more hurdles.
The example is posted. You must manipulate a Dynamic Action for the Attribs to populate. REGEN will not do it nor any FIELDEVAL setting
Reorder the Attribs as you see fit.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Oh, Forgot about the attributes having to be different in order to get things to work.
Thank you. I'll try and keep this in my memory bank.
