Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
The only time I've experienced that is trying to open a 2010 DB in something lower. There doesn't seem to be a way to convert or use 2010 DB properties, even those outside of Parametric Constraints, in older versions.
I've converted a few posted 2010 DB's to 2007 format and as you say they loose the DB properties.
