Dynamic Blocks
*Expert Elite*
Charles_Shade
Message 1 of 6 (1,747 Views)
Accepted Solution
Multiple Visibility Lisp routine
1747 Views, 5 Replies
01-23-2012 01:29 PM
Could the users of this Lisp post the several Versions here for others to find?
I have come across a few in the AUGI Dynamic Block Forum who would like to make use of the Lisp but may be running into Version problems.
(And I thought that using the subject line would help.)
Link to visibility-add-eng discussion thread:
Original Thread
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
*Expert Elite*
Charles_Shade
Message 2 of 6 (1,711 Views)
Re: Multiple Visibility Lisp routine
02-07-2012 11:26 AM in reply to: Charles_Shade
Bump - For Nikolay
Valued Contributor
Message 3 of 6 (1,704 Views)
02-07-2012 08:44 PM in reply to: Charles_Shade
Of course it is possible to check AutoCAD version before selecting an appropriate branch of user program.
But I hope that visibility-add-eng-v1.5 should work in versions 2007-2012.
As you know link for v1.5 is as follows: http://www.private.peterlink.ru/poleshchuk/cad/Download/visibility-add-eng-v1.5.zip
There is no enough statistics of using it.
Nikolay Poleshchuk
http://poleshchuk.spb.ru/cad/eng.html
*Expert Elite*
Charles_Shade
Message 4 of 6 (1,686 Views)
02-08-2012 05:18 AM in reply to: NikolayPoleshchuk
Thanks for the link Nikolay
New Member
Message 5 of 6 (1,615 Views)
03-09-2012 06:12 AM in reply to: Charles_Shade
I have a problems with the lisp...I can't get it to work. ( I downloaded the lisp "visibility-add-eng-v1.5" )
First off all I needed to change the lisp.
I placed "c:" before defun c:visibility_add and defun c:visibility_add.
Under this condition i can get to the commands in the command line after loading the app in autocad.
Real problem:
After the command visibility_add and selection the point for the visibility set, autocad place a "fantom" visibility state which appears for a second and then diappears...
After this, there is a single visibility state in the drawing, as indicated by the "VisibilityState0" shown on the Visibility pane. However, there is no actual Visibility Parameter in the editor.
What can be the solution for this problem?
THANKS!
Commandline history:
Command: VISIBILITY_ADD Select point for placing Visibility Set: _.point
Current point modes:  PDMODE=0  PDSIZE=0.00
Specify a point: 0,0,0
Command: _.BSAVE
Command: _.BParameter
Enter parameter type
[Alignment/Base/pOint/Linear/Polar/Xy/Rotation/Flip/Visibility/looKup]: _V
Specify parameter location or [Name/Label/Description/Palette]: _L
Enter visibility property label <Visibility1>: Fantom
Enter number of grips [0/1] <1>:
Command: _.BSAVE
Command: _.point
Command: _.undo Current settings: Auto = On, Control = All, Combine = Yes,
Layer = Yes
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back]
<1>: 5 (Lisp Expression) GROUP (Lisp Expression) GROUP (Lisp Expression) GROUP
(Lisp Expression) GROUP VISIBILITY_ADD GROUP Regenerating model.
Command: _.BSAVE
Command: _.point
Command: _.BSAVE
Layer = Yes
<1>: 1 (Lisp Expression) GROUP Regenerating model.
** Visibility parameter already exists in block definition. **
Command: _L Unknown command "L".  Press F1 for help.
Command: Visibility: 7ffff615 Unknown command "VISIBILITY: 7FFFF615".  Press F1
for help.
Command:
Command: VISIBILITY_ADD Unknown command "VISIBILITY_ADD".  Press F1 for help.
Command: _.point
Command: _.point
Command: nil
Command: _.BSAVE
Member
mj.harris
Message 6 of 6 (1,538 Views)
03-27-2012 10:51 AM in reply to: Charles_Shade
I'm having the same problem too........
Command: (visibility_add)
Current point modes:  PDMODE=0  PDSIZE=0'-0"
Command: _.BSAVE
Command: _.BSAVE
Command: _.point
Command: _.undo Current settings: Auto = On, Control = All, Combine = No, Layer
= Yes
<1>: 5 (Lisp Expression) GROUP (Lisp Expression) GROUP Regenerating model.
(Lisp Expression) GROUP (Lisp Expression) GROUP (Lisp Expression) GROUP Load
Application... Regenerating model.
Command: _.BSAVE
Command: _.point
Command: ; error: bad association list: (nil nil nil nil nil nil nil nil)
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
