The attached ACAD 2010 drawing contains a dynamic block with 3 different types of parameters
Block Properties Table
Visibility
Lookup (x11)
Testing them in isolation the performance is fine but now that I have all of them combined AutoCAD freezes for a second or so every time the mouse passes over the block.
Could someone please tell me what is causing it? I am hoping it is an easy fix as this block achieves exactly what I want but I cannot tolerate the performance issues.
Note if you change the scale value in the title block you need to do a regen to see the updated result.
