• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Dynamic Blocks
    Active Contributor
    Moving Text with Constraints in a DB.
    135 Views, 2 Replies
    02-12-2010 08:42 AM
    Maybe I missed something. This is really basic if you use parameters and an action, create a linear parameter and associate a move or stretch with it. But you can not do this with Constraints. What is the best way to move text in a constraint setting? I have attached a .DWG with what i am attempting to do. The Attribute on the bottom right needs to move with the right line and at the same rate.
    Thanks for any help in advance.
    Please use plain text.
    Active Contributor
    Re: Moving Text with Constraints in a DB.
    02-20-2010 01:37 PM in reply to: troy
    just add another horizontal constrain from edge of panel to text (node point).
    make sure that your snap to NODE is on.
    Active Contributor
    02-22-2010 10:33 AM in reply to: troy
    Thanks for the help.
