Show only
Search instead for
Mixing Geometric Constraints with Action Parameters
Anyone had any luck mixing Geometric Constraints with Action Parameters in 2010 or know if it is even possible?
I can create the geometry for my block using constraints and get the desired results. When I make the geometry a block and add a Point Parameter with a Stretch Action. Things start to go awry.
I can use the Stretch grip to modify the block once but if I use the grip a second time. It starts to move away from the endpoint of the line it needs to be on.
I am having the same problems. I have dynamic blocks without constraints that work fine. When I try to add constraints to them to do things that I found almost impossible to do in dynamic blocks (concentric circles) before 2010 , I have problems. I have been able to make a line drawing that works, but when I make it a block, the whole thing grenades!
You should be able to mix and match (carefully), but just watch how many objects need to be in the action selection sets - most of the time a mere fraction of what was needed before if your setting up the contraints correctly. Also, keep in mind that you should be setting up the constraints while in the block editor and not moving object pre-constrained from model space. There are some differences in the way they work between the two environments.
