<KLYPHY> wrote in messageI
href="news:6172669@discussion.autodesk.com">news:6172669@discussion.autodesk.com...
made a Dynamic Block for Bathroom Fixtures, like toilets, lavatories, bidets,
etc. I use Visibility States to be picked for the fixture chosen. It can then
be flipped or rotated as needed. What I'd like is a way to have a parameter
that I could use that would shade these fixtures to show A.D.A. compliance. I
could easily add another series of Visibility States to indicate A.D.A.
comliance, but that would double the number of State to be choose from. Can I
have one button to choose a fixture and another to show shading or not? Should
one of the buttons be a Visibility State and the other a Lookup? I'm new to
these Dynamic Blocks and Visibility States confuse me. I could use some
guidance. I appreciate any comments. Read Ya Later
-KLYPH
<KLYPHY> wrote in messageThanks
href="news:6172831@discussion.autodesk.com">news:6172831@discussion.autodesk.com...
for your quick reply. You made it quite clear and simple. Thanks again for
your help. Read Ya Later -KLYPH
<KLYPHY> wrote in messageSo,
href="news:6173713@discussion.autodesk.com">news:6173713@discussion.autodesk.com...
I've got it all working wonderfully. However, when a drafter inserts the
block, there will be 2 triangles. One for the Non-ADA, the other for ADA
fixtures. Neither triangle has any identification. The drafter doesn't know
which one to pick, until the first one is selected. Is there any text that can
be added near each triangle that won't print? Am I missing the obvious? Read
Ya Later -KLYPH
<KLYPHY> wrote in messageWell,
href="news:6173778@discussion.autodesk.com">news:6173778@discussion.autodesk.com...
I did all you said, but the triangles show no description when highlighted. I
check my Tools/Options/Display and "Show ToolTips" is checked. Am I missing
some other setting? Read Ya Later -KLYPH
<KLYPHY> wrote in messageWe're
href="news:6173826@discussion.autodesk.com">news:6173826@discussion.autodesk.com...
still using Release 2007 because all of our consultants haven't updated. See
attached block. Read Ya Later - KLYPH
href="news:6174124@discussion.autodesk.com">news:6174124@discussion.autodesk.com...
again for your input. Drafters like to complain about things that aren't
"obivous" to them. I was just trying to do my best while creating these
Dynamic Blocks. Of course, many of them have no idea how to create a Dynamic
Block. Well, someone has to make them. Might as well be me. Read Ya Later -
KLYPH
