I'm sure it's me....but I just can't seem to get it to work right.
Trying to array a series of electrical terminal blocks and then apply an end cover or partition plate to the end.
Did the array and selected the appropriate items and it leaves out the terminal block text every time.
The dwg file has two blocks in it, one works the other doesn't. The one that works I did some time ago and don't know what I did different.
I can just use the one that works but I have many other terminal block types that need to be done too.
Thanks in advance!
Sometimes there is no apparent reason.
Delete the Text in question and recreate. Make sure it is Visible in all Vis States. (You can highlight, Right click and do that.)
Add it back to the Array.
Worked here after doing these things.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
