Dynamic Blocks Forum
Is there a way to move an atribute using a Horizontal Constraint Parameter?
2 REPLIES 2
Ebbe_T_Hansen
458 Views, 2 Replies
Is there a way to move an atribute using a Constraint Parameter, when you can not connect the parameter directly to the insertion point, or is this idea simply a dead end?
The reason to use a constraint parameter rather than ie. a strecth action, is that this would make it possible to control the position dependent on other properties in a Block Properties Table.
Ebbe T. Hansen
2 REPLIES 2
Libbya
in reply to: Ebbe_T_Hansen
I do not think you can do that.  However, you may be able to accomplish what you are desiring using a stretch action and lookup table instead of block properties.
Ebbe_T_Hansen
in reply to: Libbya
You are absolutely right - it works fine. It is new to me that there is this distinction between Properties Table and a Lookup Table, and I am shure this will be usefull knowledge later on.
Thanks for your input
/Ebbe
”Boost
”Tips
”Services
