• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Dynamic Blocks
    Valued Contributor
    WillieArolf
    Accepted Solution
    Is it possible to make this objects a Dynamic Block
    164 Views, 2 Replies
    12-16-2012 11:57 PM
    Hi Guys,
    I am not so familiar with Dynamic Blocks so bare with me. I do have an object with different size and different number of sub-parts (MQRF). Would it be possible to make a "LOOKUP" dynamic block of it. If yes, what are the procedure in making it.
    I have attach the dwg file 2012 ver.
    Appreciate any info.
    Thanks & Regards,
    Willie
    Please use plain text.
    Valued Mentor
    AcadAdamLT
    Re: Is it possible to make this objects a Dynamic Block
    12-17-2012 01:54 AM in reply to: WillieArolf
    There are multiple ways of doing this dynamic, if you want it simple you could make it with visibility states. Example attached, otherwise you could do it with lookup which would require multiple parameters and actions in order to present the correct object.
    Signature, sincerely... //Adam
    AutoCad LT 2014
    Valued Contributor
    WillieArolf
    12-17-2012 04:27 PM in reply to: AcadAdamLT
    AcadAdamLT
    Thank you for the feedback. I have done it using Visibility.:smileyhappy:
    Thanks & Regards,
    Willie
