Hi Guys,
I am not so familiar with Dynamic Blocks so bare with me. I do have an object with different size and different number of sub-parts (MQRF). Would it be possible to make a "LOOKUP" dynamic block of it. If yes, what are the procedure in making it.
I have attach the dwg file 2012 ver.
Appreciate any info.
Solved by AcadAdamLT. Go to Solution.
There are multiple ways of doing this dynamic, if you want it simple you could make it with visibility states. Example attached, otherwise you could do it with lookup which would require multiple parameters and actions in order to present the correct object.
Thank you for the feedback. I have done it using Visibility.
