• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Dynamic Blocks
    Independent Visibilities
    102 Views, 4 Replies
    10-01-2008 07:52 AM
    I fear that this question may be in vain. What I want to do is have two or more visiblies/lookup within the same block working independently of one another but also together to form one block. When I say independently I more-so mean that I want Lookup tap A to effect, let say, text locations and Lookup tab B to effect, lets say, the symbols with in the block. Although tab A and tab B have everything to do with one another they would need to be separated or the combination list would be too great. What I'm trying to apply this to is a weld symbol. First, can this be done and if so how? Two, does anyone know a better option?
    Please use plain text.
    Distinguished Contributor
    Re: Independent Visibilities
    10-01-2008 12:38 PM in reply to: w35t
    My initial thought is yes, depending of course, on what specifics you want to accomplish. It is difficult to say whether or not it is possible and if there is an easier way to do this without knowing more of the block and how it functions. Are you familiar with lookup tables?
    10-02-2008 05:35 AM in reply to: w35t
    you can only have 1 VISSTATE in a block,
    but you can access a VISSTATE in a lookuptable.
    So VISSTATE 1-3 in 1 lookuptable and VISSTATE 4-6 in the second.
    However: you talk about textlocation: you don't need a VISSTATE to move objects.
    And a warning: If you create it the way you describe you probably get 1 lookup to say the correct thing, the other one will/can jump to custom.
    This is not really bad but you want to prevent this from happening.
    Menno
    *Joe Bouza
    10-02-2008 05:45 AM in reply to: w35t
    Good point. you can add position parameter with viz
    states in your lookup table: You can have as many lookups as desired but
    remember at some point another user has to use your block and or edit it so plan
    it out
    Thanks, Joe
    Joseph D. Bouza, P.E.
    Civil 3D 2008
    LDT 2008
    Win XP pro
    v 2002,
    sp 2
    hp workstation xw4600
    Intel Core Duo CPU
    E7200 @2.53 GHz
    3 GB
    RAM
    NIVDIA Quadro FX 1700 (512MB)
    The mantra of a former Flamer:
    If you are forced to eat an Elephant, don’t complain about it; Take one
    bite at a time.
    In
    memory of the King of Work-arounds
    "The only Constant is Change".
    "The only thing worse than training your staff, and having them leave is
    not training your staff, and having them stay." :-o
    A reminder taken
    from Graphics Solution Providers' Calendar
    page
    you
    lookuptable.
    second.
    to move objects.
    jump to custom.
    happening.
    Menno
    10-16-2008 01:30 PM in reply to: w35t
    I am also trying to make a dynamic weld symbol, and ran into the same problem. Being able to have multiple lookups in a block would optimal but of course no go. I'll be following this thread and if I figure out a solution I'll let you know.
