Can you import the parameters from one dynamic block into another? I have a dynamic door block which can change the size, the angle of opening, etc. I also have a window dynamic block that can stretch & also change the number of panes. What i want to do is combine these two into one dynamic block. I started with the door block & copied the window block into it. i can stretch the window inside the editor but i want to be able to stretch it when i am outside the block editor.
Notn sure you can do that.
I would just recreate the Window DynBlk.
Try Insert of the Window Block in the BE while the Door Block is open in the BE and then Explode the Window Block perhaps?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Thanks, that was going to be my next option. I just wanted to make sure that there wasnt a way to avoid having to do things twice.
The only luck I have had adding Blocks to Blocks is to use Vis States, Explode, and then add the Parameters and Actions I need back to the Block.
