Dynamic Blocks Forum
Help with stretch/move/array block
3 REPLIES 3
Nycominc
1656 Views, 3 Replies
I'm hoping someone can help me with this block. I'm sure it's something simple but I can't get it to do what I need it to.
I need this block to do the following:
1. Move the right piece so it ends at 3', 4', & 5'.
2. the move right hook and 'backing' to stetch/copy (or array) so it adds a hook to the right and fills in the backing.
     so this means that a 3' gets 4 hooks, 4' gets 5 hooks and 5' gets 6 hooks.
3. the block as shown is the smallest configuration with 3 hooks.
I could just set up a visibility and draw each one at it's appropriate length but I'm trying to keep this simple block to a min size. If all else fails, that's the route I'll take.
I've tried a couple different configurations and I keep getting duplicates or the end piece doesn't move the correct distance. I'm a little stumped. Maybe I'm overthinking it.
HELP! Smiley Sad
the attached is in ACAD 2012
3 REPLIES 3
AcadAdamLT
in reply to: Nycominc
This one should do it.
Array everything except the last segment, the last segment you just tie up with a move parameter.
Set the offset column to 10.50 on the array and set an increment on the linear parameter to 10.50 with a minimum distance of 10.50 and it should be good to go.
Edit: Ohh and by the way, don't mind the name of the dwg, there's no wipeouts, I saved over an old file that I had on desktop ^^.
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
Nycominc
in reply to: AcadAdamLT
Thank you. I had the parameter starting at the insertion point - it kept doubling up on the items I wanted to array.
Knew I was overthinking it.
AcadAdamLT
Rocket science ain't Rocket science when you know Rocket science ^^
AutoCad LT 2016
”Boost
”Tips
”Services
