• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Dynamic Blocks
    Active Contributor
    Help with arraying dnamic block
    131 Views, 7 Replies
    12-14-2012 05:55 AM
     I'm using a 2-2D recangles that are 5'x16" and 10'x16" and I am trying to figure out how to array this in one direction, to the left, but have the array on 5' increments. Also, within each rectangle I am needing text to show which size it is.
    e.g. If I drag the array to the left more than 10' but less than 15' it will apply 15'.
    Thank you.
    Please use plain text.
    Charles_Shade
    Re: Help with arraying dnamic block
    12-14-2012 07:56 AM in reply to: jarredmonday
    Please post your starting Dynamic Block and not just the rectangles.
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Active Contributor
    12-14-2012 09:09 AM in reply to: jarredmonday
    Okay, attached is the best I could come up with, but it is not doing everything I am wanting. The 5' peice should not always be visible the 10' peice should be visible at all times.
    The 5' peice should only appear on 10' increments starting at 15'.   e.g. 15,25,35,45,55...etc and not appear on 10' increments starting at  10'.   e.g. 10,20,30,40,50...etc.
    Charles_Shade
    12-14-2012 09:14 AM in reply to: jarredmonday
    So there should be a series of 10' pieces with only one 5' piece on the end?
    Active Contributor
    12-14-2012 09:49 AM in reply to: jarredmonday
    Yes. I like your description better. Thanks.
    Charles_Shade
    12-14-2012 10:07 AM in reply to: jarredmonday
    And the Dyn Blk?
    Does it do what you need?
    Active Contributor
    12-14-2012 10:29 AM in reply to: Charles_Shade
    The Dynamic block works great. Thanks a lot. I did, however add to it. I added a visibility set to show and hide the 5' section. Which just fine. See attached.
    Charles_Shade
    12-14-2012 10:32 AM in reply to: jarredmonday
    Excellent
