Dynamic Blocks
Valued Contributor
jarredmonday
Message 1 of 8 (223 Views)
Accepted Solution
Help with arraying dnamic block
223 Views, 7 Replies
12-14-2012 05:55 AM
 I'm using a 2-2D recangles that are 5'x16" and 10'x16" and I am trying to figure out how to array this in one direction, to the left, but have the array on 5' increments. Also, within each rectangle I am needing text to show which size it is.
e.g. If I drag the array to the left more than 10' but less than 15' it will apply 15'.
Thank you.
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
*Expert Elite*
Charles_Shade
Message 2 of 8 (215 Views)
Re: Help with arraying dnamic block
12-14-2012 07:56 AM in reply to: jarredmonday
Please post your starting Dynamic Block and not just the rectangles.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Valued Contributor
jarredmonday
Message 3 of 8 (211 Views)
12-14-2012 09:09 AM in reply to: jarredmonday
Okay, attached is the best I could come up with, but it is not doing everything I am wanting. The 5' peice should not always be visible the 10' peice should be visible at all times.
The 5' peice should only appear on 10' increments starting at 15'.   e.g. 15,25,35,45,55...etc and not appear on 10' increments starting at  10'.   e.g. 10,20,30,40,50...etc.
*Expert Elite*
Charles_Shade
Message 4 of 8 (209 Views)
12-14-2012 09:14 AM in reply to: jarredmonday
So there should be a series of 10' pieces with only one 5' piece on the end?
Valued Contributor
jarredmonday
Message 5 of 8 (204 Views)
12-14-2012 09:49 AM in reply to: jarredmonday
Yes. I like your description better. Thanks.
*Expert Elite*
Charles_Shade
Message 6 of 8 (200 Views)
12-14-2012 10:07 AM in reply to: jarredmonday
And the Dyn Blk?
Does it do what you need?
Valued Contributor
jarredmonday
Message 7 of 8 (197 Views)
12-14-2012 10:29 AM in reply to: Charles_Shade
The Dynamic block works great. Thanks a lot. I did, however add to it. I added a visibility set to show and hide the 5' section. Which just fine. See attached.
*Expert Elite*
Charles_Shade
Message 8 of 8 (194 Views)
12-14-2012 10:32 AM in reply to: jarredmonday
Excellent
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
