Dynamic Blocks
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Help with arraying dnamic block
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm using a 2-2D recangles that are 5'x16" and 10'x16" and I am trying to figure out how to array this in one direction, to the left, but have the array on 5' increments. Also, within each rectangle I am needing text to show which size it is.
e.g. If I drag the array to the left more than 10' but less than 15' it will apply 15'.
Thank you.
Re: Help with arraying dnamic block
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please post your starting Dynamic Block and not just the rectangles.
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Okay, attached is the best I could come up with, but it is not doing everything I am wanting. The 5' peice should not always be visible the 10' peice should be visible at all times.
The 5' peice should only appear on 10' increments starting at 15'. e.g. 15,25,35,45,55...etc and not appear on 10' increments starting at 10'. e.g. 10,20,30,40,50...etc.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So there should be a series of 10' pieces with only one 5' piece on the end?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
And the Dyn Blk?
Does it do what you need?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The Dynamic block works great. Thanks a lot. I did, however add to it. I added a visibility set to show and hide the 5' section. Which just fine. See attached.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Excellent
