First off, sorry for posting yet another message requesting help with a dynamic door block.
I'm experimenting with redoing our dynamic door block, which currently uses a scaled arc and visiblity states to control the angle. I recently read about making a dynamic door block using an angular dimension for the door swing, which automatically adjusts to the rotation of the door panel. I've tried tackling this challenge from two different angles (terrible pun intended), but I ended up being stumped either way.
Method 1: I move the width grip and everything works perfectly and smoothly until I change the door swing to anything but 90 degrees and then change the opening width.
Method 2: I get everything working, but I require two separate grips: one for the door panel and one for the opening width. I would love for them to be linked since they're changing by the same distance (just different angles).
I've attached the drawings below. I plan on adding vertical and horizontal flips to the block after I get it working (assuming it can be done).
Thanks!
Work: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 64GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
