• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Dynamic Blocks
    Charles_Shade
    Re: Help me cut down template file size?
    12-01-2009 12:52 PM in reply to: PGnirk
    http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334440&linkID=9240898
    Scale List clean up utility here.
    Regards, Charles Shade
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Please use plain text.
    Distinguished Contributor
    12-01-2009 01:08 PM in reply to: PGnirk
    Cool. Thank you! So now that I've grabbed those, I put them into the support folder where my AutoCAD files are located. I closed out, then got back into CAD. I'm not sure if that automatically runs the .exe file or not, but it didn't seem to, from what I could see. Sorry, I feel pretty ignorant at this point. oy
    Charles_Shade
    12-01-2009 01:17 PM in reply to: PGnirk
    Not quite sure myself if it does any more than what you did manually earlier. Like I said though do your template and any DB's you created over the last couple of days and you should get ahead of it.
    12-01-2009 01:20 PM in reply to: PGnirk
    Mr. Shade, I appreciate your time! I think I'm ahead of it, at least as far as I can expect at this point. You did save me some MBs, so I thank you! Hopefully I'll find a way to cut this thing in half, but I'm not too optimistic.
    I hope you have a great day/night, etc..
    Best wishes
    *T Bennett
    12-01-2009 03:39 PM in reply to: PGnirk
    You have done a PURGE, correct? It's where I always start.
    Todd
    wrote in message news:6297338@discussion.autodesk.com...
    I have created four or five dynamic blocks within our template here at work,
    and the size of the file has gone through the roof (at least in terms of
    templates go. . . . 2.8MB). It's actually bogging down one of the drafter's
    computers when he goes from PS Tab to Tab (sad, I know).
    Anyway, does anyone have any suggestions for how to substantially cut the
    file size? Is there actually a way to cut dynamic blocks down in size?
    Any ideas/suggestions would be very appreciated!
    Thank you in advance, and have a great day!
    Edited by: PGnirk on Dec 1, 2009 12:46 PM
    *T Bennett
    12-01-2009 04:01 PM in reply to: PGnirk
    Just for curiosity sake, AUDIT your drawing. Wheeee!
    I was looking for a monospaced font one time and found a nice one.
    Unfortunately, it was a memory hog and beat my video card up too. Are you
    using any special fonts?
    Another thing you might try is to narrow down which block is the memory pig.
    There may be a way to check the size of an embedded block, but I'd just open
    Windows Explorer and find the template file, select a block then
    delete-and-purge it, save, check the file size in Explorer, undo, then
    repeat the steps.
    If you thought AUDIT was fun you should try DBLIST. They probably won't
    tell you anything, but you may find something odd.
    Todd
