Dynamic Blocks Forum
Grips disappearing from dynamic blocks when using parametric constraints
1 REPLY 1
david.k.lee.ext
374 Views, 1 Reply
Hi
I have just started using dynamic blocks and parametric constrainst and have discovered that when you add a constraint to a dynamic block, you lose all your newly created grips within your dynamic block :-(.  A message box appears to inform you of this.
HOWEVER, I have managed to do it purely by accidient (ie, I've 2 dynamic visibility blocks which are contrained together and both grips work).  THis is exactly what I need, but I cannot replicate it.  Is this a bug or does anyone know how to replicate it again.
I've attached the block for anyone to have a look at.  (Block one is the large shape and block 2 is the little triangle inside). I kinda think that if it works, then why do Autodesk have this limitation.
Any help would be greafully appreciated.
1 REPLY 1
Welcome to the Autodesk Forums!
Why do you need the constraints?
”Boost
”Tips
”Services
