Dynamic Blocks Forum
Globally Edit Blocks
1 REPLY 1
Bghost12
295 Views, 1 Reply
Good morning everyone,
I have over 100 blocks that I need to add the exact same objects and visibility state to.  Is there a way to globally make this change, or even to copy the visibility states from one block to the next without having to recreate the states in each block?  I thought I had previously run across a routine on here that would make changes to multiple blocks at once, but I can't seem to find it now.  Any help would be greatly appreciated!  Thanks!
Brian
1 REPLY 1
Charles_Shade
in reply to: Bghost12
Short answer is no since each Block is unique.
I've not found a way to use Vis States and other Paramter/Actions with Copy/Paste OOTB but there may be some program language that does so but I still believe unlikely.
Parameters and Actions are tied to specific entities within each Block and unless the same entity is present in another block  (which it can't be) then Dynamic Properties will fail.
Want to test that? Draw a line, Copy it, List the Properties. What is the Handle for each? Not the same are they?
”Boost
”Tips
”Services
