Hello,I have created these dynamic blocks and let me know if there is a lisp that can generate one or more columns in the table that will deliver the code for each of the indicated blocks,for the purpose of counting or metering, I have attached the files worked.
Hola, he creado estos bloques dinamicos y quisiera saber si existe un LISP que genere una tabla completa que muestre por ejemplo el codigo de cada uno de los codos insertados, ademas si es posible actualizar esta tabla automaticamente si se genera un cambio extra en los bloques indicados.
Gracias!!
You can use DATAEXTRACTION command, but ин this way you can't insert block symbol.
see AutoCAD help: http://docs.autodesk.com/ACD/2014/ENU/files/GUID-D1433C93-0E7F-46D0-8D05-78DF3626B146.htm
In "select properties (page 4 of 8)" select "Visibility 1" property to display subcategory of dynamic blocks.
